Computer seemed to fire up and got the POST beep but no graphics. I did have the extra power cable plugged in but the card seemed to have 2 power sockets one bigger then the other.
Any idea why it wouldnt work. The card that came out was a 8800GT but went faulty in that would work fine with default PCI driver (windows) but as soon at you put the proper NVidia driver on it would bomb out. Tried card in a spare PC and was exactly the same.
Machine plays WoW (not mine its a friends.). Spec is a core 2 duo, 2gb ram. Not totally amazing and only used for WoW
Yea, you need both 6 pin and 8 pin plugs connected for the card to work properly - it is a very power hungry card.
If the PSU doesn't have any 8 pin PCI-E connections, then you can use one of these cables with a 6 pin PCIE power cable from the PSU. However, make sure you check the make and model number of the PSU - since the GTX 280 is a high-end and power hungry card - it would require a good quality 500W PSU to run stably.
Are pci 3.0 cards compatible with pci 1.0 boards?
Some PCI-E 1.0 boards will probably be able to run 3.0 cards however I'm guessing most systems with PCI-E 1.0 will bottleneck a 3.0 card (unless it's an overclocked Q9X50 chip and a game which isn't too CPU intensive maybe).
