need a midi tower case! whats the best one? :D
22 Jun 2005
hey guys! so ive got my final spec down (here it is below) and now im just picking the case! at first i read the antec 300 was the best for money so i was going to get that, then i saw that its bad for cable management! so just wondering what is the best mid tower case for cable management/airflow and cooling for around max 100 squid! oh and if it already has some sort of help for ssds thats a huge plus!
thanks!
spec is
CPU: Intel Core i7 930 2.80GHz @ 4.00GHz
Motherboard: Gigabyte GA-X58A-UD3R or Asus P6X58D-E (Socket 1366) DDR3 Motherboard
RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
Cooler: Akasa Venom CPU Cooler
1x samsung f3
2x ocz vertex 60gb ssd's
ati 5870!
thanks guys
Corsair 600t, coolermaster 690 2, the former isnt out yet, but it would be worth the wait if you want the best mid tower case it is £40 more, but if you want superior cable managment usb 3.0 built in fan controller, good looks, good build quality, then that is what you should get.
hey thanks for the rely! okay the corsair 600t seems like the thing i want! any other cases that compare to that? just want as much of a variety as possible!
thanks
I was originally waiting for the Corsair 600T but got fed up and bought the Lian Li PC-B25FB. And got to admit, pretty pleased with it. It will fit your 5870 no problem. Slightly over your £100 budget, but the best part of £45 cheaper than when it first first out.
