Permabanned
- 28 Mar 2011
- Space Man INIT
I need a neat looking way to pass 2 watercooling tubes out of my case. Case is a Lian Li A05. Any sugestions
How thick is the tubing?
I just bought some bitspower pass throughs with g1/4 thread so I can attached normal compression fittings passing through a plate. They do look good and probably the best option for yourself to go through your case.
Hi, buy a cheap set of circular saws and cut two holes in the rear of the case where ever you need them + grommets..
