Need a new 120mm CPU cooler fan
19 May 2004
Horsham, West Sussex
Hi,
The fan on my CPU cooler is working but has started to rattle so I would like to replace it.
Is there such a thing as a CPU cooling fan - like are there case fans which are super quiet because the don’t throw as much air around and CPU fans that are noisier but push much more air?
Cheers,
Nigel
Not 100% sure but it looks like a Cooler Master 411, BUT it has two wire clips that hold the fan on not the plastic frame that is shown on the current model.
My cooler is a few years old so that may just be a design change.
Anyway, as long as it is 120mm and roughly the same thickness then the wire clips will work because they just hook into the mounting screw holes.
Cheers,
Nigel
