Need a new bathroom LED Mirror
12 Feb 2009
N.Ireland
Hi, as title says, not sure of size, may be 700mm wide x 600mm high.
I don't need the cabinet type, just mirror.
Thanks in advance.
Check eBay/Amazon, same thing cheaper.
Wired ones with demisters etc are more expensive but better than battery if you have a power source.
Normally sizes are either 700x500 or 800x600 really.
is this for shaving too ?
I prefer a standard mirror, plus, pull out shaving mirror to one side, with a led bar light source above mirror, which provides more omnidirectional lumens than point source leds.
