Need a new Card for around £100
18 Aug 2004
Leeds, UK
Well my 6600GT is overheating badly, freezes in games that use heavy graphics, even with a huge house fan blowing directly on it, it still causes games to freeze, when I touch it, it is absolutely scorching. Anyway I am after a new card and it's the choice between
128MB Sparkle GeForce 6600GT AGP
BFG GeForce 7600 GS OC 512MB DDR2 HDTV/DVI (AGP) - Retail (GX-031-BG)
Hoping to go for the 7600 as I am not happy that my 660GT has blown, not had that card for no more then 8 months. As long as it plays Wow, Fear, UT2K4 and BF2 I am happy with that.
EDIT
Card needs to be AGP
7600GT AGP by leadtek is your best bang for buck on AGP, the GS isnt that powerful, i realise its a little more than you wanted to spend though :(
this may convince you...
CLICK ME
check out the blue bars, one is the GS the other is the GT.
but if you really are on a tight budget and are gaming at low resolutions/ medium settings with no AA/AF then the GS will perform well enough for you and will be a boost above your 6600GT.
