Need a new Case for SLI
24 Dec 2015
I bought 2x GTX 780 Lightnings in the Xmas Sale so now need a new case to fit them in. They are pretty big cards, something like 295mm x 130mm x 50mm so it needs to be a fair size case with. I'm leaning towards a Corsair Carbide 540 at the moment, but I'm a bit worried the footprint of the case will be too large.
I'm open to some other suggestions. Budget is around £150.
Fractal design define s or r5, plenty of space for watercooling should you want to take that route.. If not Refine S has got some extreme cooling capabilities by air.
That define s looks good value for money :) OOS at OC's though, definitely a contender.
I found it so difficult to choose a case and I had so many options.
The case I settled on was the Phantek Pro M and I do not regret it whatsoever. Its a beautiful case and has so much room for a radiator and GPU's. Take a look at this video, its what sold it to me.
https://www.youtube.com/watch?v=CS8qUvhetV4
There are two versions with open window:
https://www.overclockers.co.uk/phan...ition-full-acrylic-side-window-ca-040-pt.html
https://www.overclockers.co.uk/phan...i-tower-case-with-window-black-ca-031-pt.html
The new window design looks epic!
