- 14 Nov 2006
- UK
Being that a 8800gtx will not fit in a thermaltake shark, I need to buy a new case, what cases you all using/recommend? Thanks.
messiah khan said:Lain Li v1000?
martin9887 said:I dont like the mesh front, The Lian Li PC7 +II looks nice though, can you get a window panel for it?
martin9887 said:TT Armour is alright but I dont like the front and tbh I dont think to much of thermaltake anymore(build quality etc) as the Shark is nice but ruined by cheap plastic behind the door, I dont know what case to get, Im very picky when it comes to one lol.
I think I may try the lian li pc7 but to fit a 8800gtx you need to remove some HDD bays?(not sure).
The akasa eclipse seems to be the best choice, but I would prefer one in silver and not plastic fronted :S. The Silver Stone TJ09 is by far the nicest I've seen but its so expensive. Thanks or all help so far
Jonny L said:I think that the pc7+ II has a removable hdd cage, you could then use the floppy drive bays to put your hdd(s) in.
Jonny
