Need a new Cpu cooler - Suggestions?
10 Dec 2009
Scotland, Edinburgh
Hi all,
I currently have a Kraken x41 sitting here and unfortunately it wont work out in my new Corsair 460x Case.
I need something that wont interfere with my high profile ram and must be compatible with AM4 Ryzen.
Thanks for any advice.
Andy
Hi,
Well I have a Ryzen 1600 chip and I would like to get as close to 4ghz as possible.
Andy
not sure if you want air or liquid but after my AIO leaked I went back to air and got the cryorig quad lumi.
It runs cooler and quieter imo than the masterliquid pro 240 I had prior.
And one of the selling points was that it clears any ram.
Liquid prob your best bet if you're looking to push it hard. I'm running a Hyper 212 and am happy with it. Thankfully it came with the bracket so didn't need to wait for them to post me one out.
Thanks for the replies guys. That's the thing. I had ordered a auros gaming 7 and it arrived doa. It has a corrupt bios. So I'm waiting for a refund. I think I'm going to pick up something else. Apparently it is a relitively common bug with this board.
The other problem I have is that my ram is high profile gskill 3200.
I have a kraken am4 mount which I bought to use with the x41 before I realised it wouldn't work with this case.
Andy
Go with a AIO if space is an issue - something like the Corsair H110i has an AM4 bracket.
(Going with a giant heatsink limited my case choices - you're going in the opposite direction to me)
Without knowing what motherboard I can't say for sure, but most motherboards have 50mm center CPU to near side of RAM socket .. and there are many coolers designed to fit fan behind RAM. Cryorig H7 and H7 Quad Lumi for example. Scythe Fuma is higher wattage and will clear with only middle fan or fans in pull/ pull.
But really need to know motherboard and case to say for sure what will fit.
460X with an H150i Pro cooler fits and looks great in the front. Photo is attached.
E5rQqfi
