Hi all,
Ok at work we have an Access database thats years old, it's used to store information on our machines including stuff like admin passwords (uses a password generator to generate a set of passwords at random) and who the machine is assigned to etc, you get the gist of it.
Anyway, we need a replacement for several reasons.
The main reason being is that the password generator isn't compatible with our Windows 7 build that was released a couple of months ago also we cannot edit the data in it, again the database is very old and doesn't work properly with our build.
So I have been tasked to sorting a replacement, particularly by the end of the week...if I can pull this off, it means serious kudos
Ok now can anyone can help with any input on this and suggestions then I would REALLY appreciate it, heres the specs for what we need...this is just from initial brain storming...
When opened it gives 2 options, for either a new build or for an existing machine.
If its for an existing machine when you click on it it takes you to a page where you put in a bit of info about it, ideally the machines service tag or the users name, hit search and it brings up the entry.
If its for a new build it takes you through a process where it asks you for specific data and you have to go through a checklist, also doesn't let you pass on to the next stage or complete the entry if something is missing.
Does not run in MS Access - We are trying to get away from it due to the security issues it causes, and we are a security company, so have to follow procedure/set the standard.
Can be stored on our MS Sharepoint Site and/or accessed via a link.
Doesn't need anything special to run, for example anyone can view it if needed (theres a thought, maybe something running in IE)
Has a user friendly UI
Ok, so does anyone have any input on this? Know where I can get some kind of template I can work from, rip apart and go from there?
Thanks guys, any help appreciated
Jake
Jake
