- 18 Feb 2007
- London
hi
have installed il2 sturmovik fb on my vista pc and so far it seems to run ok,
my only problem is my joystick is crap , i tryed taking it to bits to see if i can sort the handle out as when i set it up on the pc the handle does not twist as far as it should.
and i keep crashing on il2, my joystick is a logitech force 3d.
but i would like something better thats easy and very accurate for setting it up .
my budget is £40 and must work on vista 64 bit?
cheers
cheers
