need a new monitor mount, have a new desk mounted to wall now
22 Feb 2014
Previously I had a desk that was sat slightly away from the wall allowing me to use a desk clamp style dual arm monitor mount.
I have had to move rooms and the new desk is a 3m kitchen worktop mounted to the wall, so no chance to use my old desk clamp.
SO I'm looking for a decent wall mount for dual monitors that doesn't cost the earth.
any ideas ?
Most will depend on weight of monitor in question, Without question I would recommend the ergotron LX wall mounts. Have 2 my self. They ain't cheap though
1 has a 27 Asus pb278q on it, other has a 32 chg70 on.
Down side is they don't do a duel wall mount only desk.
Cheap-ish is a GSW250D will only take up to 5k though .
both options far too expensive to be honest.
I don't need gas lift technology (although at the right price wouldn't say no)
I rarely move my monitors one they have been setup and correctly adjusted.
Current stand was around £40/50 iirc.
with this being wall mount and not desk mount I was hoping I could get something cheaper than that as essentially I am now after something much more common (and simpler)
