Need a new monitor
1 Jul 2010
Hey all,
Im looking to setup a 2nd monitor on my system but not having much luck finding what im looking for,
I require something that is the same size as my current monitor which is.
Samsung SyncMaster 931CW --- http://www.samsung.com/sg/consumer/.../LS19MEXSFV/XSS/index.idx?pagetype=prd_detail
The problem is, im having trouble finding a monitor that will be the same size as this. Im aware its a 19 inch im after but what other specs do i need to look at to make sure the monitor will be the same screen size? I did pick up a cheap 19 inch from Pc World but once on the desk it was about an inch shorter in height.
Im guessing i need to check the max res to make sure they are the same?
If someone could help me on this would be great!
It won't guarantee the bezel is the same size but you want to look out for a 19" panel of the same resolution (1440x900) as this will be an equivilent screen size to your first screen.
