I'm currently using a AVB ff turbo wheel which works without fault but sinch I've just started playing rfactor I've noticed that I cannot use the brake and the throttle at the same time(both on ther same axis).ie when you brake it cuts the throttle then applys the brake or you brake but all that happens is that it cuts the throttle with no brakes......I'm preety slow in rfactor and this is not helping my progress.
Can anyone recommend a wheel that would over come this. I don't mind spending money but I cannot aford a G25 before anyone says get one.
Thanks for any help
Thanks for any help
