Need a non gaming case with usb 3
12 Jan 2009
Hi all,
Want a case not for gaming but would like a side clear panel but must have usb 3 on the front and must be a full tower case that can take a Gelid cooler and a 6950 graphics card :-)
Looking to spend upto £100 or so on the case, must be very good quality, easy to take out the drive bays without taking out loads of screws more so slide and click kinda thing with good build quality on its interior as well as exterior.
I have looked at a few but cannot make up my mind on which one to to get I will be getting my own power supply which is a corsair tx750 v2
So you want a non-gaming case as it won't be used for gaming, but are getting a 6950?
:confused:
650D is probably the best choice if you mean that you want a case for your gaming PC that doesn't look like a gaming case. Lian Li's cases are often worth a look, but the price increases are quickly drawing them out of the £100 price bracket.
Oh I see. I'd forgotten that Nvidia don't offer that kind of setup very easily. Is there any reason they'd need such a powerful GPU? Are they going to use GPU intensive applications? If not, a lower end card from AMD would easily suffice.
I've never recommended an Antec 900 to anyone. I simply meant that obviously the 650D is quite plain, but it is a 'gaming case.'
If you move the top HDD Bracket the 650D should get it in. Let me have a little look
Yeah I've seen someone ask on the Corsair forum and yeah it can accommodate most cards - I'm off to buy a 6990 to test :p </sarcasm>.
