Need a pick up and spray general lube.
24 Jul 2004
There's nothing better getting home in the dark after a rainy, wet muddy day and then remembering you need to clean the dirt/salt off your bike.
At the moment I use a degreaser to remove the dirt and salt.
But I'd like to give it a quick greasing (wheel hubs, pegs, screws etc) - preferably a spray for ease of use.
Is there anything out there (cheap) that'll do the trick?
I have lubes and greases but nothing in spray form.
Cheers.
if its too greasy it will attract all the grit and stick to it,i just use wd40 on my wheels after cleaning the salt and dirt off
ACF50, quite easy to use, just clean your bike to a high standard and spray library avoiding brakes, tyres ect, leave to settle. then just spray with clean water when you get home. All year biker will come to your house and do a decent job if you don’t mind paying.
