Need a piece of software that can act as a journal, sort of
Man of Honour
26 Dec 2003
Shropshire
Bit of a specific one this guys.
My friend is a manager at a company which runs events and is looking for a computerised way for the radio controller to log incidents which take place throughout the events, such as ejections,first aid etc.
Now the question is, is there a piece of software that can insert a time stamp for each event entered and also time stamp any changes made?
cheers for any help you can give me guys.
Just use Excel. The shortcut CTRL+; will add todays date to a cell and CTRL+SHIFT+;will add the current time. You can use both in the same cell.
If you need to log longer incidents then OneNote would be quite good. Otherwise SB's suggestion is quite neat for something you may already have installed.
cheers for the suggestions guys il run the exel idea past him, although onenote will probably be better for a more professional look just means il have to learn how to use it :o
OneNote is quite easy to use, I bet within 20 minutes you'd be ready to get started. It timestamps the page every time you create a new one.
