Hi guys, should be a fairly straight forward answer for a plumber. I have a cold water combination valve thats leaking (the leak is coming from between the pressure reducing valve and the pressure reducing valve cartridge)
My system
https://picasaweb.google.com/lh/photo/hP_95dD8vNJtpuUzoVVavNMTjNZETYmyPJy0liipFm0?feat=directlink
Leaking Valve
https://picasaweb.google.com/lh/photo/g4nrH0Hk6-zkG830aY9h69MTjNZETYmyPJy0liipFm0?feat=directlink
Exploded View Of Valve
https://picasaweb.google.com/lh/photo/iOFFcyE6iMB8Zq6qPATfU9MTjNZETYmyPJy0liipFm0?feat=directlink
Reading through the manual it seems that it may be down to the strainer being clogged up and explains the procedure on how to remove it and clean it down.
https://picasaweb.google.com/lh/photo/R4nzzhHELJeYnyKMgSoxy9MTjNZETYmyPJy0liipFm0?feat=directlink
But my question is my valve looks slightly different. As i have a pipe coming out of where it says on the diagram 'expansion valve connection'. Does this mean if i isolate the cold water valve before the combination valve and drain all the hot water from the system. Will i be safe to remove the pressure reducing valve cartridge and clean the strainer.
The system is only 3 years old, i had it serviced 2 years ago and tbh i should really get it serviced again. Its just i thought i would give this cleaning the strainer first before I call a plumber out to say yeah the valve is broke you need a new one when in fact it only needs cleaning!
Thank you my plumber friends!
My system
Leaking Valve
