need a power supply
What sort of card is it and are you sure you need 600 Watt? I would look at the likes of this personally. Not that there's anything wrong with the Coolermaster but the Antec would be my choice.
The 8 pins will probably be 6+2 much like the 20+4 ATX 12v connector. May be best to phone through before ordering though
I'm not convinced that the Corsair 650TXV2 is worth £80. I knew Corsair would increase the price.
If £60 is the limit then I would think this would be the best option:
Antec High Current Gamer 520W 80Plus Bronze
http://www.overclockers.co.uk/showproduct.php?prodid=CA-147-AN&groupid=701&catid=123&subcat=
If that really isn't enough power for your brothers build then the next one up would be the XFX Pro 650W Core Edition 80Plus Bronze £69
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF&groupid=701&catid=123&subcat=
you sure he needs 600W?
i have no idea what his computer has, but for my build i checked what power supply i would need using this site, and went a resonable amount over the recommendation.
eg, for my build, it reccommended 446W for my worst case scenario, so i went with the BeQuiet 530W PSU, in case i wanted to add something later
(my worst case scenario was entire computer on 100% load, the fans being high performance, the CPU overclocked, etc)
as with all my posts i will say to wait for someone else to give the green light on this PSU calculator, because im a total noob when it comes to building stuff (will be doing my first build this weekend)
