need a power supply
That 660w can run as high as a cheaper 850w.
Bit if you want the best, get a Seasonic X-850 if you must.
You mean the X-860, X-850 is the old version.
The AX850 is based on the X-860.
If you were gonna put them in order of performance X-860, AX850, X850, but for the user all 3 are practically the same in performance as they are so similar. With component variance you could get a X850 sample that is better than a X-860 sample they are that close.
