Need a PSU
23 Aug 2004
I will in a moment, the website of the mobo says
- 20 pin ATX power connector
- 4 pin 12V power connector
the 4 pin is square square
triangle triangle
Just really confused how an atx 2.2 with a 20 pin connector and a 4 pin doesn't work
Worked it out, my Dad and bro were being silly (i'm trying to help them over the net) the 4 pin they're trying to use is actually the 4 you need if it's a 24 pin motherboard. They didn't realise there was an 8 pin connector which split in to two fours for the cpu. Got there eventually. phew.
