19 Aug 2009 at 17:49 #1 lamps lamps Associate Joined 26 Mar 2009 Posts 225 Location Essex Need a PSU to power a 4890 (eventually xfire) recommendations?
19 Aug 2009 at 17:51 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS or http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-PP&groupid=701&catid=123&subcat=1104
19 Aug 2009 at 17:52 #3 PermaBanned PermaBanned Soldato Joined 7 Jul 2009 Posts 16,234 Location Newcastle/Aberdeen 600W will be enough...
19 Aug 2009 at 17:54 #4 lamps lamps Associate OP Joined 26 Mar 2009 Posts 225 Location Essex does http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS have enough connectors to power 2 of them?
19 Aug 2009 at 18:00 #5 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent lamps said: does http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS have enough connectors to power 2 of them? Click to expand... You would need to use the molex to 6 pin adapters which are normaly supplied with the card.
19 Aug 2009 at 18:02 #6 lamps lamps Associate OP Joined 26 Mar 2009 Posts 225 Location Essex getting http://www.overclockers.co.uk/showproduct.php?prodid=GX-101-PC from reading 6 Pin to 4 Pin Power Adaptor is included right?
19 Aug 2009 at 18:05 #7 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent lamps said: getting http://www.overclockers.co.uk/showproduct.php?prodid=GX-101-PC from reading 6 Pin to 4 Pin Power Adaptor is included right? Click to expand... Yep, looking at the descripition, along with the usual vga/HDMI connectors
