My 3930 and Gigabyte UD4 and 32GB 1600Mhz RAM is dying and I need a replacement. I suspect the Motherboard as I get failed boots, lock ups after a stable system for many weeks. Maybe the 3930 is failing me after 2 years at 4.6 OC. I have done multiple re-installs etc. I am not sure, but it needs replacing as I use the computer for work as well as games and have the urge for my 2 year upgrade.
This is what I am looking to replace the core components with the following in a red ish theme to match my red 980. Also I am taking the opportunity to swap out the old water block I have for a new one at the same times as changing from Blue to Red fluid. I have a wide 360 push pull rad on top just for the CPU, way overkill.
YOUR BASKET
1 x Asus X99-S - Intel Core i7 5930K Six Core CPU & Motherboard Bundle ***£30 Saving*** £694.98
2 x GeIL Super Luce 16GB (4x4GB) DDR4 PC4-24000C16 3000MHz Quad Channel Kit - Red (GLR416GB3000C16QC) £179.99 (£359.98)
1 x Watercool Heatkiller IV Pro Intel - Acrylic Clear £49.99
1 x Mayhems Ice Dragon Nano Fluid 1L £23.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x Mayhems Dye Deep Red 15ml £5.48
Total : £1,158.01 (includes shipping : £8.00 Ex.VAT).
I was toying with a 5960 and Rampage V, but I don't need all the bells whistles, wireless etc and I rarely max the 6 cores I have and for the sake of another £600+ I am not sure it is worth the 5960 and R5.
Is this a sound build and does it all match?
Thoughts before I go to OCUK tomorrow with card in hand ?
- I use it for Elite Dangerous and iRacing with a NVidia 980. Not a massive gamer, only these 2 games.
- I mainly use it for processing work and VMWares - hence 32GB RAM
- I have the CPU under a water block and have plenty of rad space and plenty of case space and will "mild" OC the CPU to 4Ghz.
- I will not OC the RAM, just want 32GB and 3000Mhz stable RAM
YOUR BASKET
