Need A Replacement Case
9 Dec 2006
@ManCave
Basically, My Current case is to big it doesn't fit under my desk, im thinking of looking for one that fits. (plus don't like this one that much)
you can see here:
http://smogsy.co.uk/photos/cache/smogsy/room/DSC_5459_w600.jpg
It getting on my nerves i want it to fit under the shelf behind the leg. keep hitting my legs when using the Mac.
So Max size Requirements
Height 520mm (MAX)
Width 600mm
Length 3000mm :D
Requirements
Fit Full size cards in SLI (5/680GTX etc)
Fit my Nortuca CPU Cooler
Good Airflow (big fans are good)
budget <£300 but rather spend nothing :o
or i could mod my current case to have no feet or arms any ideas if this can be done?
RV02 or RV03 or FT02B or RV02W-EW.
I am pretty sure my case is 460mm height with the FT02B being slightly taller i think?
