You need to check whether BT have changed their policy on requiring the white OpenReach modem to be connected and doing the VDSL part of the connection. Admittedly you do then need to check whether you care... but that's up to you.
In theory, anything capable of supporting VDSL2 should work unless BT have nobbled the connection in some way similar to the way Sky have. OCUK stock at least three routers depending on your budget:
