14 Sep 2015 at 20:29 #1 Trent10182 Trent10182 Associate Joined 6 Aug 2012 Posts 49 Location Falmouth I don't know much about power supplies but I need a replacement for the one stated in the title.
14 Sep 2015 at 20:49 #2 ShivP ShivP Soldato Soldato Joined 26 Oct 2013 Posts 9,926 Location Leicester What system will it be running? What budget?
14 Sep 2015 at 21:07 #3 Trent10182 Trent10182 Associate OP Joined 6 Aug 2012 Posts 49 Location Falmouth GTX 670 Z77X-D3H i5 3570K I have around £100 but can go a bit higher.
14 Sep 2015 at 21:11 #4 ShivP ShivP Soldato Soldato Joined 26 Oct 2013 Posts 9,926 Location Leicester You'll be fine with just a good quality 550-650W unit then. For a fully modular unit at that power range you're looking at the EVGA GS 550W Would you ever SLI the 670s? If so, you'd be looking at around 750-850W
14 Sep 2015 at 21:17 #5 Trent10182 Trent10182 Associate OP Joined 6 Aug 2012 Posts 49 Location Falmouth Sorry I meant to say 970, would that still be good, I probably won't be using SLI any time soon.
14 Sep 2015 at 21:21 #6 ShivP ShivP Soldato Soldato Joined 26 Oct 2013 Posts 9,926 Location Leicester 550W would still be fine. The GS is an excellent unit
14 Sep 2015 at 21:25 #7 Trent10182 Trent10182 Associate OP Joined 6 Aug 2012 Posts 49 Location Falmouth Okay then, thanks for the help.
