Need a thin 80mm but unsure if oc do them?
8 Dec 2012
UK
Hi all,
I would research this myself but I don't have the time at the moment to be able to do this myself.
I'm doing a build and have a case I'm re-using for this build; however the front intake 80mm fan bay isn't very spacious so is there any 80mm thin fans that OC's sell which have good air flow to noise ratio?
Thanks in advanced :)
A full build for £200?
TOTAL PRICE £195.77
Need to replace a 80mm fan though as 34mm in height is too big lol
Had a look but it seems OcUK doesn't sell any <25mm thick 80mm fans. Seems like one of these may be an option if you can find one <Clicky>
Found one but it's like £18 odd so that is too expensive.
Out of the 25mm height ones which is best buy based on air flow to noise ratio (prefer pwm)?
