Need a upgrade from a super.fi 5 ...help
5 Jan 2004
im thinking of Sennheiser HD595, any ideas? Budget is about £140, its going to be for indoor use so size doesnt matter. Mostly going to be used for music.
,thxs
You should check out Beyer's open headphones, the DT990s, as well as Grado (I forget which one pair is cheap enough). If you can find somewhere that stocks them I'd recommend giving each a listen and deciding from there.
