need a water block for gpu
21 Jan 2012
Hereford, UK
Hi guuys I am installing a loop in my rig I have xspc D5 ex 240 kit and whant to add another 240 rad and cool my gigabyte 7970 windforce 3 oc edition my problem I dont think its a reference card so does anybody know what I can use such as a universal block perhaps?
So I just enter pcb code off card and it will tell me what block I need?
Am I right in thinking code is by the pcie connection?
Thanks for replying
Go down the page to 'Select your video card'
AMD > GPU Series (Radeon HD 7970) > Select Manufacturer (GIGABYTE) > Select Video Card (Gigabyte 7970 windforce 3 oc edition pcb GV-R797TO-3GD)
It will then list/show you which universal blocks you can use.
Thanks guys my one worry is cause the universal only do gpu chip would I see high temps on water rather than gains due to v ram no longer being cooled?
