Thanks to the genius that built my house my telephone socket is in the bedroom, it's a new flat built in a field so contention and distance from the exchange is crazy. My router used to sit in the living room under my TV with loads of non Wi-Fi devices connected. It's now relocated to under my bed, but I cannot relocate my 46" LED TV, Blu-ray and ReadyNAS Duo under there.
Engineer from Tiscali came out and improved my internet connection from 96kbps to 1.4Mbps to do so he relocated it from the living room to the bedroom and fitted a NTE-2000 faceplate, which means I cannot even move it back to the living room if I wanted as it has to be plugged into the master socket now. Although worth it for the increase from 96kbps to 1.4Mbps.
So...
Is there such a device that I can connect my wired devices to, and it using Wi-Fi will give them access to my router and all other devices on the router access to my ReadyNAS Duo?
Or do I pay BT to re-wire my house 'cos I have a lovely Netgear DGN3300 under the bed, and a ReadyNAS Duo not connected to anything!!! Please help me OCUK? I would like to connect 4 wired devices.
So...
