Im on virgin 20mb broadband, using Linksys WRT54GL router flashed with tomato firmware, it works great
im on VM 20 mb and have a belkin router i recommend you not to get a belkin router i have several problems when using the wireless router with downloads freezing and have to use the cable modem for downloading if u go on VM home page they admit there is a problem with belkin and VM and they offer no support. get a linkseys or something else
I wouldn't bother with n for now, it won't be final until November, so there's no guarantee that draft n equipment will be fully compatible with the final equipment, or that it will be able to be upgradable to the final spec.Buy a Linksys, if you get a "N" it will be last Router you need for many years, just check the internals can actually cope with 20meg and 50meg later in the year
I'm with JFan, a WRT54GL and tomato it.
