Need advice an help
30 Jan 2011
My pc I built myself a long time ago with just little help off friend and internet i'v upgraded it over the years but now its almost pointless trying to do anything on it.
I have many problems like freezes games crashing really slow load up an so on here is a basic tex of what's in my machine sorry not sure how to insert link to it any help advice would be great thanks
System Information
Time of this report: 8/17/2016, 20:30:15
Machine name: GAVLAD-PC
Operating System: Windows 10 Pro 64-bit (10.0, Build 10240) (10240.th1_st1.160623-1726)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-990FXA-UD3
BIOS: Award Modular BIOS v6.00PG
Processor: AMD FX(tm)-8320 Eight-Core Processor (8 CPUs), ~4.0GHz
Memory: 8192MB RAM
Available OS Memory: 8190MB RAM
Page File: 3154MB used, 13226MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
Display Devices
Card name: AMD Radeon HD 7800 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6819)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_6819&SUBSYS_27301462&REV_00
Display Memory: 6123 MB
Dedicated Memory: 2029 MB
Shared Memory: 4094 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: BenQ GW2760HS
Monitor Model: BenQ GW2760HS
Monitor Id: BNQ78CA
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,amdxc64.dll,aticfx32,aticfx32,aticfx32,amdxc32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1474 (English)
Driver Version: 16.300.2311.0
DDI Version: 12
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Are you looking to upgrade or help with the issues?
A budget and what you use the PC for will help peeps point you in the right direction if your looking for an upgrade.
well if my pc cant be sorted i'll prob go an buy a new one I have a rough idea
picked out some stuff from OC site buget about £1000 have peripherals so just on pc but any help with repairs would be great
I use my PC for gaming only
OcUK Tech Labs AMD FX Midi Tower Gaming PC Configurator
Stock Code FS-014-TL
£1,088.74*
£1,088.74*
Your selected configuration: Edit Configuration 
Mechanical Hard Drive 1 Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
Power Supply XFX XTR Series 750W 80 Plus Gold Fully Modular Power Supply
Operating System Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
CPU AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail
Motherboard Asus Sabertooth 990FX R2.0 AMD 990FX (Socket AM3+) DDR3 Motherboard
Memory Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16)
CPU Cooler Akasa AK-876 AMD CPU Cooler
Build Time Standard Build Systems - Dispatched within 7 working days
Case Kolink Aviator Midi Tower Gaming Case - Black
Solid State Drive 1 Samsung 500GB 750 EVO SSD 2.5" SATA 6Gbps Solid State Drive
Graphics Card PowerColor Radeon RX 480 8192MB GDDR5 PCI-Express Graphics Card
Im no expert on advising what hardware for you to buy but buying AMD 8 core will not give any real performance gains from what you have.
Plus its a dead socket now. For your budget im sure the chaps will come up with a much better Intel build for you.
£1,088.74*
£1,088.74*
Dude thats not a lot of performance for your money, is there any reason you went down the pre-built route?
You could probably get more for you money, one of these guys will spec you but I doubt it will be AMD for a CPU.
No reason really just thought OC mite well build it better than me lol.
I have always had AMD but open to anything any help be great
Just put an RX 480 into your current system. If you really want a new build then go Intel (Or wait and see what AMD Zen brings).
Do you know what make/model power supply you have ?
I'm not sure what the spec of the unit is as. I'm fairly sure it's an HEC unit. Seems to be available from the rainforest and blue shirt brigade (£70 from the blue shirts)
It's a 780W PSU, but only has 2 PCI-E 6-pin connectors. That has me questioning the internal quality of the unit. It is probably OK to use with a 480.
so just upgrading the graphics card will solve my issues my 7850 is old an worthless now?
I would look at replacing the power supply as well. A 550W is enough for a single graphics card.
As for the 7850 keep it as a spare, as you never know when you might need a backup.
A SuperFlower Golden Green would do fine if you don't mind a non modular power supply.
My basket at Overclockers UK:
Total: £76.49
(includes shipping: £10.50)
Or a Leadex if you want modular (As long as you don't mind the LED connectors).
Total: £90.49
Total: £76.49
Total: £90.49
What's wrong with the power supply?
Think it was just a quick fix a while ago when had problems I really don't mind buying a new system I've had my rig for prob about 10 years+ now upgraded many times but its the same rig maybe time for a full upgrade
Want to play things like battlefield one on high settings without poor frames an slow loads an what not for that I would need SSD for sure an i7 ?
as above you already have an FX8320 no point in building a Machine running an FX8350..
Do you have an SSD?
I would be looking at a graphics card upgrade and an solid state drive as a system drive with a clean install of windows. this should speed things up a bit.
and as above get a good power supply in there. a weak power supply can cause strange problems. when I first started I had a cheapo 750watt PSU but after replacing it with a quality branded one I found my system responded quicker
also if you are using a stock cooler bin it and fit an aftermarket cooler this should allow a moderate overclock.
what case do you have? has it got good airflow?
If you still decide you want to upgrade through time I would say go intel but you could use the parts you buy and move them over to the new build.
when I built my first intel machine I was coming from an FX8350 and I noticed my games ran so much smoother. it was a worth while upgrade.
I would always keep an old graphics card unless it doesn't work. Having spares can be very handy if you're fault finding. Especially if your motherboard doesn't have onboard graphics.
An SSD will speed things up quite a lot. You don't need a complete new system with an i7. All you need is an SSD, a graphics upgrade and a decent PSU. I do tend to get a bit obsessive about PSUs:D
I would definitely consider replacing the PSU as well. Although it's been working fine, it could well be of dubious quality inside. Having had a look around the web, there's conflicting opinions about the OEM and it's listed in Tier 5. That's the same level as CiT PSUs!
Just to add a bit more variety, the Antec TruePower Classic is also £65 and is a very solid PSU:
https://www.overclockers.co.uk/antec-truepower-classic-550w-80-plus-gold-power-supply-ca-202-an.html
The G7 780W isn't a good unit. The fact that it only has the 2 x pci-e connectors sets alarm bells ringing. A high quality 750W unit would have 4 x pci-e minimum.
It could also be one of the reasons why you are currently getting freezing/crashing issues. If the unit can't supply the power then the pc will become unstable.
If you want to start from fresh then yes an Intel cpu is the way forward at present. It could change once Zen is out but we won't know that until release.
The early benchmarks that are going around it doesnt look to promising but hopefully there wrong it would be good to see intel with some competition in the cpu market.
Thanks a lot for the help an advice guys very helpfully place this is.
So my current cpu 8320 is ok? think I have it running at 4.2ghz
Just so you know best way to help me i'm sort of guy that don't mind cost as long as its the best I can get for the money
So new psu
new graphics card
And a SSD
Should make my computer run a lot better ?
What's best card I can get for my current rig
Is my motherboard
Many thanks again for help sorry to keep asking so many questions lol
So new psu
new graphics card
And a SSD
Is my motherboard
An RX 480 or GTX 1060 would probably be the best bet with the FX-8320. Anything higher than that would probably give you bottlenecks, as the cpu wouldn't be able to keep up.
You could go for a GTX 1070 but you probably wouldn't get the full benefit. Even an i5 can have some bottlenecks with a GTX 1070 at 1080p in certain games.
Also if you are adding an SSD then I would look at doing a clean install of Windows, as you want that as your boot/gaming drive. So a Samsung Evo 250GB for example should have Windows on it and then install the games on it as well. Just use the HDD for mass storage of large files.
Just download all the drivers beforehand on to a USB stick for the motherboard from gigabyte website, and also the graphics card driver from the manufacturers website or Nvidia (GTX 1060)/AMD (RX 480) depending on what you go for.
I would suggest either the Sapphire RX 480 Nitro if you want another AMD card (It is pre-order) or a Gigabyte GTX 1060 Windforce for Nvidia.
The SuperFlower Leadex is the better psu in the list so long as you don't mind the 'LED' connectors. If you don't want light up connectors then the XFX XTR is still a very good unit.
The Samsung 750 EVO is a good SSD. The 850 EVO is a bit faster if you want to pay the extra. You probably won't notice much difference though.
Total: £736.91
(includes shipping: £0.00)
So you are probably looking at a bit over £400. and if the worst comes to worst and you are still having issues, then you still have cash left to switch to Intel.
ive got the 750watt version of the XFX xtr and have no complaints. in fact its that good a unit ive got one in my sons machine as well
