Hi all,
After bought a LG 29UB65-P as a 4th monitor I notice my GPU is struggling slightly when having all 4 on and working with them (the other 3 is Dell 2412M). So a 2nd GPU is needed which will be the Vapor-X one, to match what I got. Was told I be needing 800+ PSU though and think the one I picked will be enough, but also thought since I need to change it maybe find one with color braided cables but no clue if the pre color braided cables that can be bought will be ok using with the SuperFlower or if have to use same brand for PSU vs Color Cable's ?
YOUR BASKET
1 x sapphire radeon r9 290 vapor-x oc 4096mb gddr5 pci-express graphics card (11227-04-40g) £233.99
1 x superflower leadex gold 850w fully modular "80 plus gold" power supply - black £89.99
1 x avexir golden blitz 8gb (2x4gb) ddr3 pc3-19200c10 2400mhz dual channel memory kit (avd3u24001004g-2bz1se) £79.99
total : £413.57 (includes shipping : £8.00).
the above is what is presently in my basket, so need suggestions on psu cables (have to be honest and admit if i would try and pick the cables myself i probably would miss some and things wouldn't work out) and possible another psu if it wont work with the superflower one. also, the memory sticks not sure if needed but seen rather few posts here saying 1600mhz sticks not that good (which is what i got right now so thought i add the blitz).
have added the below picture of my pc's inside incase it makes things easier for you experts on "blinging" things up a little. would it look out of place to have blue cables you think ?
My full spec is as follows if needed for PSU consideration:
Gigabyte Z97X-UD5H Intel Z97
Intel Core i7-4770K 3.50GHz (Haswell)
Sapphire Radeon R9 290 Vapor-X OC 4096MB
Corsair HX750 PSU
TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
Intel 335 Series 20nm 240GB 2.5" SATA 6Gb/s Solid State Hard Drive x 2
Couple HDD's: 2 x 3TB and 2 x 750GB
Corsair Hydro H100i High Performance Liquid CPU Cooler
ASUS Xonar D2 PCI
ASUS BluRay Combo BC-12D2HT
Come to think of it, think my Xonar is on it's last leg, sometimes after I listen to music or watched a movie there is some sort of "pitch" coming from the speakers (I think it is due to sound card and not the speaker system itself) so might have to swap that to if you got any recommendations.
Budget: none really, as long you not getting to carried away.
Thank you for reading this and I appreciate any and all suggestions you might have !
PS: Sorry for long post.
YOUR BASKET
Corsair HX750 PSU
ASUS Xonar D2 PCI
