Hey all,
Thinking to get myself a sound card again for my Logitech Z-5500 speakers and Logitech G933 headphones. But, have no clue what to get exactly. Mostly be using it for gaming, some music and occasional movies.
Been looking around a bit and found these three that I'm trying to decide between.
Creative Sound Blaster X AE-5
ASUS Strix Soar 7.1
Terratec Aureon 7.1
Also in regards to the cards, should I plug in my PS4 Pro to the sound card or the Z-5500 Control unit ? The unit can take Optical, Coax and 6-channel direct. If I understand right, means I can connect both PC and PS4 to it ?? If not, directly into one of the above cards ?
In any case, I do need some expert advice in regards to the above card from those that have or are using any of them. If you have other recommendations I am open for those as well !
Appreciate any and all help in the above !
ASUS Strix Soar 7.1
Terratec Aureon 7.1
