hey all,
I have an opty146 which i currently run at 8.5*340 = 2.9ghz. Using a divider my cheap PC3200 samsung ram runs at 220mhz at; 2.5-3-3-8 using 1T. I am considering buying some better ram, First off do you think this will be worth it? I mean the fastest ram I can see will run up to 275mhz. would it really be worth paying £150 odd just for 50mhz increase on the mem bandwidth side? If so what ram would you recommend?
