My sister has asked me for advice on buying a PDA to use for her work. PDA's are something I know very little about, ask me to spec and build workstations, servers and network infrastructures....I'm your man!
however no one I know owns/uses a PDA.
She needs it to have a mail client preferably MS Outlook to sync to her laptop and check email on the move.
She'll also be updating the CRM software her company use in real time, so I assume she'll be connecting via VPN.
The budget she's been given is £190. However she could go higher depending on the spec!
She has been looking at two already:
HP iPAQ RX 1950 <--- PDF Spec Sheet
Palm T|X Handheld
What would you recommend?
however no one I know owns/uses a PDA.She needs it to have a mail client preferably MS Outlook to sync to her laptop and check email on the move.
Palm T|X Handheld
