Hi everyone,
I’m hoping someone here might be able to offer some insight or advice. I’m not hugely tech-savvy, so please forgive me if I explain anything poorly. I’ve been dealing with an increasingly frustrating issue on my system, and I’m reaching the point where I don’t know if there’s anything left to try, or if I should just sell the GPU as faulty and cut my losses.
I have a Gigabyte RTX 3070 Ti, It boots fine, outputs display, and works on the desktop with no issue at all. The problem is that whenever the card is under any sort of GPU load, it either crashes the game back to desktop, freezes the application for several seconds, or causes a display driver timeout, worst case has been a total freeze of the computer, to which I had to hard-reset, though this has been a very rare occurrence.
This happens in pretty much every game I’ve tested and even a few testing environments such as Kombuster, MSI Afterburner, etc
I’m just trying to decide if it’s worth sending off for repair, or if I should just list it on eBay as “Faulty / For Parts” and be done with it.
Apologies if this is long-winded or if I’ve missed anything obvious — I’m not a hardware expert, just someone trying to make the most out of what I’ve got. Any advice, suggestions, or direction would be massively appreciated.
Thanks in advance.
What I’ve Done So Far:
- Multiple clean driver installs using DDU in safe mode
- Tested a wide range of driver versions (from 522.25 to the latest 572.x)
- Undervolted and underclocked the GPU via MSI Afterburner (down to 1800MHz / 900mV and lower)
- Tried multiple power limits and fan curves
- Reseated the card and cleaned contacts with compressed air
- Swapped PCIe slots (note: card only works in the top slot — nothing at all in the second)
- Disabled PCIe Gen4 and Gen3, forced Gen2 in BIOS
- Fully reinstalled Windows 11
- Logged detailed telemetry with HWInfo (no abnormal temps, voltages, or power draw before the crash — temps stay below 50°C)
- Tried limiting FPS and lowering game graphics settings
- PSU is a Corsair 1000W Gold modular, and everything else in the system is stable
- Event ID 13 – “Graphics SM Warp Exception: Illegal Instruction Encoding”
- Event ID 153 – “Reset TDR occurred on GPUID:100”
Thanks in advance.
