- 26 Aug 2004
- South Wales
I need some new speakers, my current ones are basic Typhoon ones from Aldi or Lidl and must be at least 17 years old. They're going bad, for a little while i noticed a buzzing noise from them, but lately every time i turn them on the buzzing is quite loud and then it goes quieter after some seconds, today i went to turn them on and it might have been louder so i just turned them straight off because I'm not sure if they're safe.
I've seen some Edifier ones suggested, looked them up and they seem to get good reviews only they are said to have more bass even when turned right down, which i don't think i want.
Creative T40 look good, but spoiled a bit by some stupid energy saving feature which you can't turn off, no good for notifications.
Closest I've seen that look almost right is probably the PreSonus Eris E3.5.
Just looking for decent speakers with bass and treble control, i don't want to spend too much but up to £100 is fine, I'd rather not go much above that unless there is a big jump in quality. Needed for all around use, so games, bit of music and videos etc.
Suggestions?
Suggestions?
