- 10 Jun 2010
- Scotland
Hi guys,
I'm after a little bit of advice. I've put together a system using a
Gigabyte H55M-UD2H, i3 540 and Geils 1600Mhz 4GB kit.
I've never worked on a system with this new technology before. The BIOS was such a shock to me, what happened to the good old FSB. Life was much simpler then
I have never worked on a DDR3 system or anything beyond my current rig. Basically I am looking to confirm I have setup the BIOS correctly, as there were a tonne of settings and values to input.
The RAM was set to 1333Mhz by default, I knew this would be the case, although I wasn't sure how to go about it. Anyway, I upped the "BCLK" to 160 and lowered the multiplier to 19. This gave me the 1600Mhz I was after on the RAM and lowered my i3 back to 3.04Ghz (3.07Ghz Stock)
Also when in the Ram settings there is Channels A & B. I presume this is for Dimms 1-3 and 2-4? I manually set channel A to 9-9-9-28 as stated on the Geil RAM. It was by default 9-9-9-24
The RAM voltage was on auto at 1.5V, it's rated between 1.4-1.6. I just left this on Auto as middle of the road seemed fine to me.
I never touched the "Advanced A Timing Control" I have no experience with these values and was unsure, so left all on Auto.
I never found an XMP profile in the BIOS. Must not support it.
I updated to the latest F11 BIOS. I also disabled all the power saving facilities that reduce vcore and frequency, for all you would save on the electricity bill anyway. I hope this is alright to do? I know I disable speedstep on my X38 board.
Basically I am just looking for re assurance that this is the correct way of making the RAM run at it's rated speed. Something is niggling away at me telling me this isn't the correct way to do it.
Anyway, if the likes of "Stulid" or "CMNDR_ANDI" want to give me some words of wisdom it would be greatly appreciated.
P.S what's with all the complicated settings, thing's used to be so much simpler, a FSB, multiplier, enter the ram timings, adjust the voltage on the ram and cpu and away you go. Now it's like launching a space shuttle.
Thank's again in advance to those who can offer any advice, much appreciated.
I forgot to mention. Windows 7 user experience index only gives the ram a score of 5.9. I know it's a really poor benchmark utility and should be taking with a pinch of salt. However my Corsair Dominatoe DDR2 at 1066Mhz scores significantly higher at 7.3. Surely DDR3 RAM at 1600Mhz should slaughter that? Am I wrong? (again)
