So hello people, I need you're help and advice, HDD unreadable / Bios problems
(this was my first time, wished I asked for help before hand)
Sorry its like an long paragraph/article, im explaing everything I did
Well yesterday, my new motherboard and cpu came so I took my gpu, HDD and RAM and stuck it in my new motherboard and turned it all on (I did have the "new motherboard, no signal problem but fixed it) and then I did what it said in the booklet that came with the mobo "load deafult CMOS" from the bios so I did that and restet my system but it didnt work, it just kept going to the windows recovery screen. after that I unplugged everything and went back to my old motherboard and used that for the night (everything was working fine)
So today I found out how to correctly update the bios for my new motherboard, so I downloaded the bios update I needed and put it on a pen drive and reset my system, but when my system reseted a black screen come up with an underscore at the top right, so i unplugged everything one by one and found out it was my HDD was not reading.
So I need your help guys..
Is there anyway to make my HDD readable again and work my new mobo or Will I have to buy windows 7, a new HDD and do it all on new mobo?
