- 17 Aug 2011
So im not pro at graphics cards, as in, i look at the MB and think that's all you really need to go by, but recently i got a new game (final fantasy 14) and my old GeForce 8600gs, 512MB is no longer good enough
However, being on a tight budget (£50ish) i can't just go out and buy a £130 snazzy thing. 512MB Nvidia 9600 series is minimum (me personally dont get the difference between the 8600 and 9600, both 512mb, hence why im coming here for help ^^) 768MB GeForce GTX460 or better recommended.
Considering the age of my current graphics card (and computer) i figured finding one at this budget should be possible, and i know i cant be picky, but im plugged in to a 26" HDTV, so one with HDMI socket would be nice.
I found this, but i don't know if it is above the previous cards i mentioned and designed for gaming, and i cant find many reviews i understand about it. with what i understand, £47.99 seems rather cheap to me for it.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-158-EA&groupid=701&catid=1914&subcat=
Also, afraid i do only have about 23cm length wise of freedom before it hits the (what i think is the) processors. If need be i was thinking of getting a new case, seen one or 2 that do have reviews, but due to my money situation, im only going to get what i need.
Thank you for reading
