Need advice on a gaming chair.
1 Nov 2013
Hi,
I've started having neck problems due to the time i spend on my computer so i need a chair which supports my neck as my current chair only comes up to my shoulders.
Budget wise as cheap as a possible however prepared to spend whatever it takes within reason.
In what way are gaming chairs better than standard chairs ? my assumption is because its called a 'gaming' chair there's a premium attached so happy for reccomendations outside the gaming arena also.
I've seen a lot of Pro's use dx racer chairs. I see the formula dx racer is £240ish here at ocuk. How do you find the neck/head rest ? i need to have support for my neck and feel most of my neck problems are due to this crappy cheap leather chair i have.
do they come with the padded neck rests?
whatever you do stay away from vertagear, they just ignore any problems you have such as me and my missing cushions, really disappointed with their customer service.
i only got mine because it has a high back and was supposed to have a neck support cushion.
I was considering getting a vertagear actually as they had some good reviews on here.
So your chair had a missing cussion? how is the chair itself?
its ok, it swivels around and the back folds forward and back, the arm rests move up down left right forward and backwards, the head area is quite far back for me without a cushion and i like leaning back on it even though i think im going to fall on the floor it's quite stable and you can easily tighten the spring so it doesn't tip backwards quickly, the seat is quite hard at first but it's getting softer now (had it a month) i've already fallen asleep on it leaning back lol, and visually looks great i got a white and black pl6000
