- 9 May 2005
I wasn't really sure whether to put this in the Home Cinema section or in here but seeing as its to do with a screen I thought the intelligent folk of monitors may be able to offer some advice.
Basically in the next two weeks I am looking to buy a new screen, its only going to be a smallish one (approx 19-23inch) with a max budget of £200 (I can stretch to £300 if its really necessary but it will mean I will have to hold back on my planned video card upgrade).
The screen is going to be used for a range of different uses, below is a list of what I will be mainly using it for.
1- PS2/PS3 gaming
2- PC gaming
3- General PC usage (Internet, dvds etc)
4- Watching TV
So the way I look at it is that I have two choices, I can either get a monitor and a TV card or I can buy a LCD TV. I think the TV idea is the best as it will be ideal for TV (obviously
) be suitable for console gaming (16:9 ratio instead of 16:10) and it can be used as a monitor too.
But then a 1680x1050 screen would be better for PC gaming
and this is where I go round and round in circles lol. What would you do in my situation and is there any screens that I should be looking at? I have been looking at the LG range though I am not sure if they are any good or not?
LG M198WA 19" LCD TV/Monitor 1440x900 300cd/m2 3000:1 5ms VGA/DVI Black
http://uk.lge.com/products/model/detail/multifunctionmonitor_m198wa.jhtml
1- PS2/PS3 gaming
2- PC gaming
4- Watching TV
) be suitable for console gaming (16:9 ratio instead of 16:10) and it can be used as a monitor too.But then a 1680x1050 screen would be better for PC gaming
and this is where I go round and round in circles lol. What would you do in my situation and is there any screens that I should be looking at? I have been looking at the LG range though I am not sure if they are any good or not?LG M198WA 19" LCD TV/Monitor 1440x900 300cd/m2 3000:1 5ms VGA/DVI Black
Also I am not sure what it looks like running at 16:10 ratio when the native is 16:9, just a little stretched, maybe?
