Hey guys,
I've been building and upgrading my PC for about 7 years now, though I've never done a big build. It started as a basic gaming PC and every year I upgrade a component or two to keep up with the requirements for gaming.
I recently started planning a "fantasy" build that hopefully soon I'll be able to start. For power and for looks. I've decided this time that I want to do a custom water cooling loop. Ive been doing a lot of research over the weekend and evenings and I've come up with a plan that I'd like to do. I've never done water cooling before, so I need some advice.
This will be housed in a Corsair C70 Vengeance Case
My basic plan is...
Reservoir will either be a single or dual bay reservoir with pump. Probably the EK ones. Unless anyone can suggest otherwise (I don't think I'll have room for a separate pump).
CPU Block will probably be the EK-Supremacy Clean (intel i7 4770K).
Top radiator I was thinking XSPC EX280 (mainly because it's thin), along with corsair SP140 fans.
VGA Block will be EK-FC770 GTX (Nvidia GTX 770).
Bottom radiator will probably be the XSPC EX140 with corsair SP140 fan. I think you can fit another 280 on the bottom but it's pushing it very close to the PSU and means I have to remove a front fan.
From there it goes back up to the reservoir.
I'm planning on using 16/11mm tubing and bitspower fittings. With mayhems orange pastel coolant.
Question time ...
1. Is there anything obviously wrong with this setup?
2. Would this setup give me room for overclocking and possible expansion (of for example another VGA or motherboard block)?
3. I read somewhere not to mix metals. Does that mean I can't mix copper with nickel? Not a problem if so but I need to know because I might have to change a block.
4. I plan on adding two temperature sensors. Where is the best place to put them (the sensor I mean, not the display)?
5. I've see a lot of builds with taps at the bottom of the build. I assume that's to help out with coolant changes etc. Is it worth having one?
Think that's all for now. Any advice would be extremely appreciated.
Thanks
Stewie
My basic plan is...
Question time ...
Thanks
Stewie
yeah I've found loads of good pics of that case. All the ones with a double on the bottom look very restricting on space behind the PSU though. I'll look into it when I get the case.
