Ok i'll be honest this is my first build, getting ****ed of with the crap thats loaded on pcs when you buy them plus i need something powerful
as it will be use to run multiple multithreaded softwares &
programing softwares
dont think i need a top the range graphics card as its never going be used for gaming or anything mostly just coding but one that can run multiple monitors
ive been told to get around 16gb + memory
need everything apart from mouse, keyboard, and monitors
oh i kinda like this case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-129-AN&tool=3
so everything and anything to fit inside also hard drive dont need to be huge as mostly all work is stored on external drives so 500gb or less would be fine
budget £1000 better if less, but not big deal if its over that
thanks
Budd
thanks
Budd
lol)
not so important for a gaming pc where the data is just being read all the time.
lol
