Need advice on buying new Oled TV.
B&W
B&W
3 Oct 2003
Birmingham
Looking for a 65 inch OLED for main living room which size wise is 22 foot long by 15.5 foot wide.
It will be mounted on a media wall.
TV area of media wall is 183 cm wide and 104 cm.
Main usage will be movies, TV shows through mostly streaming services. Plan on adding a blu ray player and soundbar eventually.
I'm thinking of waiting for prime day deals I've got an eye on the LG C3 oled. For £1400 odd seems best buy.
Are there any other contenders for same price range?
Looks like you can fit a 77 inch TV in that space :)
77 inch Sony A95L QD-OLED
171 x 98.5 x 3.5
77 inch LG OLED evo AI G4 4K​
TV Dimensions without Stand (WxHxD)
1712 x 982 x 24.8
But there going to cost a lot more then £1,400
You say the room is 22 feet long , But what the viewing distance from the TV ?
171 x 98.5 x 3.5
1712 x 982 x 24.8
3 to 3. 5 metre viewing distance.
I'm in a dilemma now as I have another sitting area with a media wall that's got a space for a larger TV then the other media wall.
However this sitting area/kitchen I have purchased a 65 inch Samsung neo qled qn90c as it was on offer. Not installed yet I'll attached pics of both. I thought Samsung would be perfect here as the kitchen has skylight and large patio doors. Plus the viewing distance will only be 2. 5 metre
I have attached pics here
The pic with the flat packs in front is the kitchens media wall and the other one is the living room (larger viewing distance here)
Maybe best to go with the 65 inch as it could be really awkward mounting a larger TV in that inset with no free space to get your hands in to hold it
Unless you get one of them TV brackets that can move the TV outwards and you mount the TV to it and then push it back in
Something like this https://amzn.eu/d/0aTs3HzJ
Nothing good on prime day, think I'll wait before pulling the trigger.
LG oled 77 b3 looks promising, 1500 at the moment.
Wish I didn't buy the neo qled as it will most likely go in main living room but with the vouchers I had I got it for £880 Inc vat so almost half the price.
