Im selling off my old rig to make room for my new E6300, X1900XT machine. Previously I had a Antec Sonata II and used the provided PSU. It's a AMD 64bit 3200+, Nvidia 6800GS, 2gb Corsair value select, one DvD drive and no PCI cards. It worked just fine.
So I have to buy a new case + PSU for my new rig, but I want to keep it around the £80/£90 mark. The Sonata II would be ideal again, but im worried about the PSU. The rig is:
HIS X1900 XT
Core 2 duo E6300 (with Zalman CNPS9500-AT Aero Flower)
Gigabyte DS4
Geil PC6400
One DVD drive and one TV PCI tuner card.
How would the provided PSU fair with these specs? I do plan to overclock the balls off this rig.
If no, then I need to keep it fairly cheap. If I spend £50 on the PSU (Looking at the Seasonic S12 430W Silent ATX2.0), that leaves me with only £40 (MAX £50) for a case. Im pretty picky on styles, and im not that keen on side windows.
Does anyone know how the Thermaltake VB1000SNS Soprano SuperMidi Tower is for sound levels? Its the only case I can find around that price range that I like the look of. Never seen one up close, of course.
Q1. Sonata II PSU good enough?
Q2. Is the Thermaltake a good case? Sound levels in particular.
Any help would be appreciated
HIS X1900 XT
Gigabyte DS4
Geil PC6400
) and a Tagen or something PSU, I'd say that you'd need something like a decent 430w or 500w PSU for that Conroe rig.
) so it should be a solid construction and a decent case.
