Need Advice on Dominator Ram Upgrade.
25 Sep 2012
Hello,
I am looking to upgrade by doubling the RAM. Currently still using DDR2.
2 x 2gb Corsair Dominator (Cm2 x 2048-8500 C5D) Ver 1.1
Being fairly outdated getting hold of a matching pair is difficult, however I found a later version (Ver 2.2) which also runs at 5-5-5-15, and 1066Mhz.
Does this mean that I can buy the newer version and run in tandem with the earlier version, or will this be setting me up for many headaches in the future?
Currently running the pentium E5300 @ 2.6GHz and
Gigabyte GA-EP31-DS3L Motherboard
Thanks in advance for any advice you might be able to give!
