Hi all I need some advice on a potential upgrade. My current rig is the spec in my sig. I have had my i5 3570k for 3 years and it has been fine, along with my 7950 GPU. I have been thinking of building a new system either a Skylake or an Haswell i7, but looking at costs I am wondering if I will gain or performance will be only a little noticeable. And also I suspect I would need more than my Antec 650W PSU for this system?
My main use is gaming, so probably an i5 would be better and cheaper but when Fallout 4 recommends an i7 then I was thinking if this would be a regular thing in the future even though most games don't use it.
My other option I was thinking as I need a new case as well was just upgrade the GPU to a R9 390, an extra 8 Gb ram, new case and SSD and maybe overclock the CPU a bit.
What do you guys think I should do??? Thanks in advance.
