Need advice on my WC build.
18 Sep 2011
Hey, long time lurker here.
I purchased Swiftech H20-220 APEX Ultra kit about 3-4 years ago now and finally got around to wanting to watercool my computer. I understand that the CPU block which comes with it probably wouldn't fit, so i'm wondering what will I need to have a "full kit" for an 1155 chipset.
I will only be using the kit for my CPU. The contents i have is -
Radiator - MCR220-QP
Reservoir - MCRES-Micro
Pump - Laing D5 Vario Pump -T12 12V DC Pum
Tubing - eight feet of 7/16" industrial grade tubing
Two ounces of HydrX coolant
Any advice which CPU block i should get and also any other parts i would need to complete the above? A block around £50-60 pref.
My computer specs are(just incase) -
I5 2500K @ Stock
nvidia 250gts
Asus P8P67 LE Rev3 Intel P67
8GB Corsair DDR3 Vengeance Racing Red, PC3-12800 (1600)
Corsair 520W PSU
CM 690-II Lite
Thanks for your time, and any advice is greatly appreciated.
